First off, I’m a newbie. I mean, I can understand and curious enough to find solutions, I’m using Linux as my os, but I am far from a programmer.
I got the Daisy Seed with the Synthux Simple Touch, and everything was working well and could try a few sounds and play around. After a few months not using it, I decided to play around with it again but this time I seem to have an issue. When I press the Boot and Reset buttons to get it in bootloader mode, nothing happens, no flashing light and cannot upload with Arduino IDE, got an error message, the same message you get when you don’t put it bootloader mode - the power light is always on. I did:
try different combination of Boot and Reset pushing buttons, but mainly used the one I read everywhere: hold Boot, press Reset and release, and release Boot.
try different usb cables (3), including the one that was working before.
try on my linux laptop and my wife’s mac.
I did some research and couldn’t find anything about that issue. I’m hoping to find some help here.
Yes, I meant flash mode, and when I do the process you just described, hold Boot, click the Flash (Reset) button, and release Boot, nothing happens, the led doesn’t do a single pulse, and I got the message error when I try to flash something. Even when I just press the Flash (Reset) button, the led keeps still. Arduino IDE do recognize it is plugged, but I don’t seem to be able to get it in Flash mode.
Ok, but it still doesn’t work when I do that. This is the error message I have:
Sketch uses 32412 bytes (24%) of program storage space. Maximum is 131072 bytes.
Global variables use 5132 bytes (0%) of dynamic memory, leaving 519156 bytes for local variables. Maximum is 524288 bytes.
Selected interface: dfu
STM32CubeProgrammer v2.20.0
Error: Target device not found.
Establishing connection with the device failed.
Failed uploading: uploading error: exit status 1
And the device does show as connected in Port.
I followed these instructions for setting up the USB for linux and it worked before:
Now I’m wondering it it means the daisy has an issue. The power led works though.
I don’t have a Linux system here, so can’t be much help. I’d suggest putting it in flash mode, and using lsusb to see what VID and PID are showing. If the Daisy shows up, I don’t think it’s a hardware problem. And I’d try a different USB cable.
Sorry, I should have been more clear, I was responding to @Seb ‘s: “nothing happens, the led doesn’t do a single pulse”, and quoted you to avoid retyping the instruction on my iPad.
