Hothouse DSP Pedal Kit
Legend :metal:
It will be interesting to see where that goes, but I suspect Electrosmith will want to maintain a clear separation of concerns. Sometime soon, I need to fire up the Arduino IDE, get familiar, and have a think about how best to support it; ideally, in the form of a complement to/extension of DaisyDuino. (I have exactly 0.0 hours of experience with that ecosystem, so “good intentions” and all that …)
I ordered a hothouse a few weeks ago and I’m loving it! I’ve written an overdrive effect as my first foray into DSP and I’m really happy with how it has turned out. One thing I’ve discovered is that at the default block size of 48 and default sample rate of 48kHz there is 1kHz noise coming from the ADC. It appears that this is a known issue with the daisy seed (see https://forum.electro-smith.com/t/questions-about-digital-noise-and-grounding/) where there is noise at the frequency sampleRate/blockSize. In that other thread there are several hardware workarounds mentioned, and I’m not sure if the hothouse is using any of those, but I’ve resorted to reducing block size to 4 samples at 96kHz sample rate to move the noise up to 24kHz and out of the audible range. This is probably not an issue for most use cases, but I am boosting the input signal by up to 96 db at which point the noise becomes significant. I wanted to point this issue and my workaround out in case anyone else runs into the same problem.
Hey jeffffff,
I don’t have any 1kHz noise in my hothouse. The fact that this frequency is aligned with the frequency of the data blocks (48 kHz / 48 samples = 1 kHz) makes me think that you have a bug in your software and that it’s not a problem with the hardware.
Can you post your code? Or, can you share a github link?
Here is an example reproducing the 1kHz noise issue with minimal modification to an empty effect from “create_new_proj.py”: https://github.com/jeffplaisance/HothouseExamples/blob/main/src/EmptyExample/empty_example.cpp
what it looks like in a spectrum analyzer with no input, there is a clear spike at 1kHz (and also 8 kHz):
I’m almost certain it’s not a software issue. FWIW, the 1kHz noise is only 10-15 db above the noise floor, and the noise floor on the pedal is pretty low! It is unlikely to be an issue for anything other than an overdrive/distortion/fuzz pedal or maybe a compressor pedal. I didn’t mean this as a criticism of the Hothouse in any way, I think the hothouse is really great and would strongly recommend it. Just wanted to let people know how to work around this issue in case anyone else happens to run into it.
Can you please make a v2 with sidechain input?
Anyone doing a eurorack enclosure for this?
This wouldn’t make much sense to me. You’d need to change the power input and modify the audio levels to comply to eurorack. This and the stomp buttons not being very handy inside of a modular makes it not particularly worthwhile to do, imo.
Of course it would be cool to have a Eurorack specific Hothouse-like product. Say a Patch.Init() with more knobs and switches, basically.
But this is up to @newkular to envision and execute :wink:
I agree with @dreamer here. To be useful in a Eurorack form factor, the mechanical, circuit, and UX designs would need an almost total overhaul. That’s not to say I’d never do it, though. The idea of a Eurorack version has been on my backlog for a while now … it just wouldn’t be a “Eurorack enclosure” for the Hothouse.
Can you elaborate a little bit?
like have a main input for music, but also a secondary input channel that I can use to duck the main input for example. Like The Pill or Polyend Press.
Cheers for the clarification; that’s what I thought you meant. I’ll add it to the backlog. However, it seems a highly-specialised feature at face value. I’ll have a think about how to make something like that apply to other use cases.
Since the Hothouse is a true stereo pedal as it is, one could use one of the input channels for a sidechain signal. Of course, this means you’re limited to one channel of audio. But that might work in many use cases.
yeah that’s the thing, I usually have my song in stereo but want to duck it by the kick sound for example
I’ve added it to the backlog. Cheers for that! A popular YouTuber recently started a series on using Plugdata with Hothouse, so interest has spiked … meaning the backlog is growing quickly. Total transparency: this feature is below things like MIDI I/O and an expression jack for a v2 :person_shrugging:
The problem is this would require an additional codec for more audio inputs.
So this greatly complicates the design.
Exactly ^^ At that point, you’d have a completely new set of use case possibilities, but it’s a different beast altogether (and in a different price range).
I’d easily pay 2x the price for sidechain input. There are so few pedals that allow that.
I’m getting started with developing my own software for Daisy/Hothouse and I am curious if anyone has noticed coupling between the stereo in/out?
My concept (to start) is a basic FX blender, a knob to control dry → wet, with code that mixes from 0 to 1 multipliers on the 2 inputs. My setup is: guitar to dry input (in[0]) → fx send (out[1]) → fuzz pedal (JHS Crimson) → fx return (in[1]) → out (mixed between these two based on knob).
The problem I’m facing at the moment is even when the mix knob is fully to dry (I logged that it actually hits zero, and I even tried subtracting a bit…), I hear a bit of fuzz as opposed to my fully clean tone. The splitters I’m using seem pretty janky, so I’ve ordered some more, but I had one other cable from TRS to dual mono TS that seems okay, and I swapped it in and the issue remains.
I’ll try adjusting things, but would love if anyone has pointers or ideas?
I’d first try a simple stereo passthrough program to determine if there is any coupling in the hardware.
Good call on testing stereo pass through. I recorded myself saying “left left left” in one channel, and “right right right” in the other, played that through the pedal (just passing directly through) and at first didn’t notice any coupling, but I was at “normal” levels.
Then I used fuzz in one channel, and noticed it was bleeding a bit.
Then I cranked up the vocals-only output to where it was clipping, I was able to hear the ''left” channel in the “right” input.
Luckily, some new cables had been delivered, and when I swapped things out I narrowed it down to these: Amazon.com: Togconn 2-Pack 1/4 inch TRS Stereo Splitter Y Adapter, 6.35mm Stereo Male to Dual 6.35 mm TS Mono Female Jack, Quarter inch Audio Speaker Splitter Converter Cable 1 Feet, Gold Plated Connectors : Electronics
When I used some alternate cables the problem was gone entirely. Phew!
