@Assaf Silly question: have you tried quitting and reopening terminal?
The path variable doesn’t update until you do so. That may be why oopsy can’t find the arm toolchain.
What is strange is that brew is saying that gcc-arm-embedded is already installed, but then it can’t be found.
Can you try to run:
brew reinstall gcc-arm-embedded
and then afterwards try to invoke the command itself:
arm-none-eabi-gcc --version
This may at least confirm if the tool is installed or not.
There is also a related thread on github that some people have managed to resolve the progress on. Though as far as I know, others on the M1 mac (and BigSur) have been successful in getting it to work with the install.command.
Hope that’s helpful, let us know how it goes or if you need more assistance troubleshooting.
Got it up and running thank you!
What fixed it for me was using git to clone - otherwise the install.sh of oopsy doesnt work - and the errors were not very obvious
Hey, took me time to answer but it did work! thanks for your help!
Hey! Glad to hear it.
Hi All , cant get helper to run on windows in MINGW64. Any advice? i have installed it.
@Zifor depending on when/how you installed git-bash, python may have issues running within that terminal. Usually this results in a stalled terminal when you try to invoke python or a script that calls it.
There are a few things you can do:
- You could rerun the latest git-bash installer, during the optional settings there is a specific option for allowing virtual terminals (like
python/nodeto run). Check that. - More of a workaround, than anything else, but you can should be able to run
helper.pyfrom a different terminal like Powershell, or the command prompt.
Hope that helps ![]()
I solved the issue , I just diddnt follow the EXACT install method of python on windows. Word of warning for other newbies!
