Hey all together,
I’ve got a question about the Init Funktion for DaisySeed Objects.
When calling the function for the hardware it calls the “ConfigureAudio()” function amongst some others. In this function an AudioHandle::Config object is created and the following instructions are called:
AudioHandle::Config audio_config;
audio_config.blocksize = 48;
audio_config.samplerate = SaiHandle::Config::SampleRate::SAI_48KHZ;
audio_config.postgain = 1.f;
audio_handle.Init(audio_config, sai_1_handle);
However if I’ve understood it correctly by reading the source code, Config is a struct inside the AudioHandle class. And the constructor for the audio_config Object already initialises these values. So aren’t these definitions called twice as a result?
Thanks in advance and best regards,
Lucas
