The main source of program memory usage with CMSIS DSP FFT stuff is the constant lookup table (LUT) data used for various sizes of FFT. I believe in older versions of CMSIS DSP all the LUTs for all the supported sizes are linked into program data, whereas with the newer versions allow you to specify which ones you want to compile/include via preprocessor definitions.
The latest main branch of libDaisy was recently updated with a newer CMSIS DSP version and if you’re up-to-date with the main branch, something like this will work in your makefile (adapted from one of my own projects).
# Config Options
MY_FFT_SIZE = 1024
# Definitions for FFT
C_DEFS += -DARM_DSP_CONFIG_TABLES -DARM_FFT_ALLOW_TABLES
ifeq ($(MY_FFT_SIZE), 512)
C_DEFS += -DARM_TABLE_TWIDDLECOEF_F32_256 -DARM_TABLE_BITREVIDX_FLT_256 -DARM_TABLE_TWIDDLECOEF_RFFT_F32_512
endif
ifeq ($(MY_FFT_SIZE), 1024)
C_DEFS += -DARM_TABLE_TWIDDLECOEF_F32_512 -DARM_TABLE_BITREVIDX_FLT_512 -DARM_TABLE_TWIDDLECOEF_RFFT_F32_1024
endif
ifeq ($(MY_FFT_SIZE), 2048)
C_DEFS += -DARM_TABLE_TWIDDLECOEF_F32_1024 -DARM_TABLE_BITREVIDX_FLT_1024 -DARM_TABLE_TWIDDLECOEF_RFFT_F32_2048
endif
ifeq ($(MY_FFT_SIZE), 4096)
C_DEFS += -DARM_TABLE_TWIDDLECOEF_F32_2048 -DARM_TABLE_BITREVIDX_FLT_2048 -DARM_TABLE_TWIDDLECOEF_RFFT_F32_4096
endif
# ... rest of makefile ...
It’s a little bit clumsy to do it like this, but it works - whatever MY_FFT_SIZE is set to determines which LUTs are actually compiled and linked. There’s also some kind of python configuration tool included with CMSIS-DSP that seems to automate some of this but I’ve not tried to integrate it with the libDaisy Makefile build process.
Of course, with larger FFT sizes the LUT data still might not fit into program memory internal to the STM32, so you may need to use the Daisy Bootloader instead.
