@Takumi_Ogata ,
Is there any ETA on when this may come out?
Thanks,
Brett
@Takumi_Ogata ,
Thanks,
Brett
Hi Brett,
I’m not sure the ETA for the new Daisy Bootloader.
You can edit in that question to here: Need help: "Failed to launch GDB: Load failed" -- when the load succussed - #6 by BHAudio
For anyone looking at this thread in 2023, libDaisy now implements a function System::ResetToBootloader(). Calling it from your program will put the Seed in DFU mode, even if the program lives in Flash and you’re not actually using the libDaisy bootloader. Great way to prototype firmware on Seeds that live in enclosures where the USB port is accessible but the boot / reset buttons are out of the way…
@Takumi_Ogata @alo.bu
Is there a full article somewhere on the new updates?
Hi Brett,
V6 may not be officially released yet.
Apologies in advance for the necro-post.
Does anyone have a working example of this? daisy::System::ResetToBootloader(); definitely halts the Seed and perhaps resets it, but it doesn’t seem to put the Seed in DFU mode for me.
Works for me. This code blinks for about 10 seconds, then enters the builtin STM bootloader:
#include "daisy_seed.h"
DaisySeed hardware;
// Declare a variable to store the state we want to set for the LED.
bool led_state;
led_state = true;
int count = 0;
hardware.Configure();
hardware.Init();
// Loop forever
for(;;)
// Set the onboard LED
hardware.SetLed(led_state);
// Toggle the LED state for the next time around.
led_state = !led_state;
// Wait 500ms
System::Delay(500);
if (++count > 20)
Bah. Procedural programmer brain strikes again. I was trying to trigger it after a footswitch is held down for one second, but was miscalculating the timer increment across the AudioCallback() and a System::Delay() call in int main(). It’s not even worth posting the errant code. Basically, my brain was vapor locked ![]()
